ek dx front disc upgrade?
96civic808
i would like to upgrade my 96 civic dx front disc.
i searched but only shows rear disc conversions.
do i just change the rotors from the dx to Ex rotors?
what else need to be done?
You need to get the entire knuckle assy. To my knowledge integra calipers will not bolt up to civic spindles. This upgrade is well worth it btw.
If im not mistaken, the EX and Si front brakes (on the 96-00 civics) are the same size, and the DX fronts are smaller. So you can upgrade to EX fronts seeing as they are more popular than the Si's.
if u got a d16z6 tranny in a 93 si hatch and u put gsr suspension complete assembly on which axlxes would u use the d series axles or the b series??? lmk
i got the d series axles 2 work. i had 2 use a sharp pick and clean out the grooves. i can't beleive that . it looked brand new when i took the axles out. just goes 2 show u that something so little can e lude u.
