00 civ&90 hatch
ok i got a 00' civic ex which originaly was a vtec motor that motor blew and i jus did a y7 swap into it while i'm building my ls/vtec turbo set up and i switched my y8 intake mani over to the y7 my problem is that i get the code that it's looking for vtec and it's not there i picked up a p2e ecu from a 99 civic dx which it should work but it's not it's not idling at all something with the iacv and since i have the y8 intake manifold it's a 3 wire iacv plug and i need to know if 99-01 dx's are a 2 wire and if so wat throttle body is it cuz honda made 2 different 2 wire setups so i can use the right throttle body atleast thats wat i was told to look for i'm so lost on the situation if neone knows anything that could help me it would be greatly appreciated
