EK rear disk swap
Discussion in 'Wheels / Suspension / Tires / Brakes' started by noobvang, Mar 24, 2006.
  1. noobvang
    noobvang Senior Member
    Twincities, MN
    95 4dr ex rear disk -----> 96 4dr lx
    My question is will everything swap over for the rear disk conversion? I know that parts from a 94+ integra would fit but for the 92+ civics, I'm not completly sure.
    If the do fit, what would you recomend my pulling out of this car before it gets junked.
  2. bcman
    bcman Senior Member
    Davis, CA
    as far as I know, the entire rear trailing arms should swap over. there might be a difference in the length of the e-brake cables, but they'll probably fit too. I'd also recommend taking the master cylinder if it's a 15/16" and the proportioning valve if it's a 4040.
  3. GSRCIVICTN
    GSRCIVICTN Lost in a sea of rednecks
    Nashville, TN
    Not trying to be a smartass(not 100% sure), but don't you mean 60/40 as in ratio of the distribution of pressure from front to rear? If not, please explain what 4040 means. I really don't know what that is.
  4. bcman
    bcman Senior Member
    Davis, CA
    Honestly, I'm not sure what it means either, but it's the proportioning valve used in hondas with rear discs, as opposed to a 3030 for rear drums. the 4040 sends more pressure to the rear, since discs require more pressure to produce the same braking force. the number should be printed on the casting.
  5. GSRCIVICTN
    Nashville, TN
    I see. Thanks. Didn't know they were called that. Good to know.
