ek suspension on an eg
Canadian_GSR
Ok I was offered a smokin deal on some new suspension gear and its off my buddys 98 civic, im wondering if it'll install on my 95 civic. I know this is probally a common question but I appreciate any advice. Thanks.
By "suspension gear" you must mean shocks and springs... if so, yes, IIRC the springs will move over fine. Not sure about the shocks but 80% sure that they will.
just checked and the front shocks will definitely fit... not sure about the rears though but they'll probably work.
99-00 si fronts won't
lca's are different on front and back
but other than that, springs, shiocks will transfer over
You can use the front and rear 96-98 shocks, the fronts bolt up, but on the rears you need to shave down a few mm's on your LCA bushings.
