hondasnowman
i have a 99 hatchback it used to be an automatic cx, i have put in a 92-95b16a jdm eg motor with a 98 ex harness on it. the problem is i have one plug left hanging out from under the dash that used to plug into the auto ecu. i have been told that this is the plug for the auto trans but i found that it also has a signal wire in it for the main relay to kick the feul pump
so i guess i need to swap out the dash harness for one out of a 5 speed ??????
I NEED HELP PLEASE!!!!!!! WHAT DO I DO???????
