Ek wont start
ek9power
Yes i have a 97 ek hatchback.my problem just happened.at first it had the cel light on and it read at that it was th iac valve. So i drove it for awhile then it just dided.so i looked at my fuses it was my fuel pump fuse so changed it then it started running again.the just yesterday i tried startin it but it wouldnt it turns over but wont start.i looked at the same fuse and it was blown so thinkin switching would work i did but i just kept blowing the fuse and i dont want to waste anymore fuses.so if you know of this problem please help really apreciate it??thx
Sounds like something is shorting out if you keep blowing fuses. Pull the back seat and check the wiring going into the pump.
sounds like the greasy plug for the fuel pump is gone dry and water is shorting it out, i had that happen out of the blue on one of my customers car
