There is GREEN jack/connector next to the 3 ECU jack/connector in the 96 EK3 VTEC harness. Can any one tell me the purpose of this jack/connector or where does it go to.
If it is approximately the same size as the ECU plugs it should plug in near the bottom of the dash on the passenger side (its for the ignition etc,) if it is a smaller plug it is just a port for checking error codes that the ECU sends out.
