Ek6 D16y8 - Tighter Steering?
Discussion in 'Wheels / Suspension / Tires / Brakes' started by EK6teenY8, Jan 13, 2003.
  1. EK6teenY8
    EK6teenY8 Junior Member
    Is there any possible way to achieve tighter steering on an EK6 chassis D16Y8 factory Honda Civic? I would like the steering to feel as if it was an SI. Nice, tight and smooth. Any help would be greatly appreciated!
  2. E_SolSi
    swap the stering rack
  3. EK6teenY8
    Do I need anything else other than the steering rack?
  4. sportlinecrx
    sportlinecrx Banned
    get a front upper strut bar..and a lower front tie bar. you can also upgrade your suspension bushings to aftermarket polyurethane bushings. other than that, you can get a carbon fiber hood to lessen the weight of the front end a little. if you want to go all out, you can get a chassis brace (i think thats what they are called) and rear upper and lower tie bars. if you did all that, you'd be handiling way better than a stock si.
  5. knowledge
    knowledge Senior Member
    Beale AFB, CA
