Originally posted by radnulb@Nov 23 2003, 07:40 PM
what ECU are you using to run this? (I ask for the hell of it - shouldn't really matter cause...)
It sounds to me like you have an electrical issue. Specifically, I'd look for shorted wires. Blown fuses are the usual visible problem that is caused by shorted wiress. The ELD measures electrical load. I would bet your ELD code after the fuse popping is the ECU detecting the short causing an electrical overload. I'd look carefully at any wiring you modified during the swap. I'd also try unplugging any stereo amplifiers you may have, and check any power wires for them very carefully. Normally these problems fit together...
I might be 100% wrong here too - I'd like some of the other geniuses here to give their opinion too.
