electrical prob?
Discussion in 'Civic and CRX - EF' started by evilneo, Aug 12, 2008.
  1. evilneo
    evilneo New Member
    kunkletown, PA
    I have a 91 crx hf (1.5 sohc 8 valve) when i am running the car voltage is fine for a while. then as i hit the throttle voltage goes down. replaced alternator,still the same but if i unplug voltage regulator voltage stays at 13.88 but then i have only 1/4 throttle and if i push it to the floor nothing happens. Also if i am driving car will not let me go past 4,000 rpms until warmed up but lose power after 4,100. wondering if it is a wiring problem?:(
  2. t3t4delsol
    t3t4delsol New Member
    York, Pa
    large system?
  3. evilneo
    evilneo New Member
    kunkletown, PA
    nope just a head unit
  4. BoostedHatch
    BoostedHatch get tha fuck out!
    Bossier City, Louisiana
    sounds like you need to set your timing back or forward.
  5. George777
    George777 ^^ Likes Bewbies
    With your mom
    Electrical gremlins
