Emergency, what causes car to act like it's out of gas
Discussion in 'Civic and del Sol - EG and EK' started by xj0hnx, Oct 18, 2012.
  1. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    but it isn't? I was taking a turn on the way to work, not too fast, just a normal turn, and the engine suddenly choked like it was out of gas, and now it won't start like it's out of gas, but no it's NOT out of gas. ten bucks was put in day before yesterday, gauge is well above the E, and the light hasn't been on.
    So it cranks hard
    I can hear the fuel pump
    I literally need this fixed by 12 noon, so lol 2.5 hours
  2. E_SolSi
    filter?
    are you getting fuel at the rail?
  3. xj0hnx
    C.C.TX.
    That's my next stop, just got it towed here to our shop, but it isn't an automotive shop so I don't have any tools :( No manual for this gen either, so going off my faded memory isn't helping with bolt sizes lol
  4. Briansol
    Did it run ok yesterday? there's been cases where tanker trucks have put diesel into gas tanks. Try snifing the tank (within reason).... or try calling the gas station you filled up at to see if anyone else has reported issues.
    pull plug #3. fouled?
    check the fuse box for popped fuses
  5. xj0hnx
    C.C.TX.
    Would an engine seizing go out like that? Or would there be some more noise associated with it?
  6. xj0hnx
    C.C.TX.
    It ran ok, thirty seconds before it died lol. IT was good, drove around the corner and bam.
    Now it has been doing this kind of loss of power thing in low gears, while accelerating, but I have been attributing it to AC.
    We added two more gallons of gas too, so having fuel is not the problem, I removed the fuse for the fuel pump, and put it back just to make sure I was hearing it right, and it is coming on.
  7. E_SolSi
    also if you can take a look at the timing belt
    had this happen on my mazda... the spring on the tensioner broke and the timing belt went slack
    was running fine and then suddenly stalled out
    would crank but wouldnt even try to turn over
  8. Briansol
    smell the tank. you should be able to smell diesel. even to the touch, the fuel feels different. the same thing happened to wild bill a while back. it wasn't instant after fill up. it was about the next day when it happened.
  9. xj0hnx
    C.C.TX.
    Ok, so fuel is definitely making to the bottom bolt of hte filter, now I gotta get the banjo bolt on the top of the filter off
  10. xj0hnx
    C.C.TX.
    Timing belt has a cover on it, would have to take of valve cover, not too bad, just time consuming. I am at work too :(
    How can you tell if it's the TB without looking at it?
  11. E_SolSi
    is it cranking faster than normal?
    if its not making compression it will generally crank fast
  12. xj0hnx
    C.C.TX.
    Nope, cranking normal, timing belt is still there, only saw the top, but it is tight still. Fuel is definitely making it through the filter. Next stop if spark ...
  13. xj0hnx
    C.C.TX.
    No spark, gotta determine if it's the cap, or ignitor
  14. xj0hnx
    C.C.TX.
    Gotta b ignitor
  15. xj0hnx
    C.C.TX.
    Are the D series vtec, and non vtec dizzy's the same? Will say a 1995 DX fit a 99 EX? Should be right?
  16. E_SolSi
    the VTEC and non-VTEC SOHC distributors have the same part number
    but the OBD-1 and OBD2 have different part numbers
    i know the plugs are different
    OBD-1 has 2 plugs OBD-2 has 1 (the wire locations match between the 2 if you are looking at repining one)
    not sure if anything else is different about them
  17. xj0hnx
    C.C.TX.
    It was the fucking coil. Tested it with a multimeter out of the car, at Autozone, read different than a new one, put in the new one, fired right up.
  18. Briansol
    sweet! glad you'r eback on the road.
  19. E_SolSi
  20. dc4dude
    dc4dude Member
    chicago, il
    Good shit dude! Glad it was a speedy recovery!
