emission test...
Discussion in 'General Tech and Maintenance' started by dvus1, Aug 21, 2003.
  1. dvus1
    dvus1 Senior Member
    somewhere in GUAM
    problem passing my 90 civic HB, thru DMV inspection line here in dover. I failed the emission test. (still stock engine) :D
    Got any ideas... coz i need to sell the car already...
  2. CRX-YEM
    Wallingford, CT
    If you just want it to pass here's a suggestion.
    Go to home depot buy denatured alcohol or MEK if you can find it.
    run your gas take almost empty, make a mixture of denatured alcohol to gas
    the ratio is 2 part denatured alcohol to 1 part gas (example 2 gals : 1 gal)
    you will pass emissions with flying colors. the mix doesn't have to be 100% perfect.
    but if you really wanna fix the problem I'm not to sure were to start looking as it could be anything.
    It's similar to running E85 , it's a newer alternative fuel being used these days. which burns way the f*ck cleaner than petrol.
    Some literature to read up on about new alternative fuels.
    e85fuel.com
    Ethanol info
    I think B. should take my info on cheaply passing emissions tesst and make it a sticky.
  3. dvus1
    dvus1 Senior Member
    somewhere in GUAM
    is that the same thing as putting Guranteed to pass emission (fuel additive).
  4. zoarette
    zoarette Banned
    the 1990 civic has two valves starbored and one on the portside, this was the first two valve operating exuaost 20 min before you get tested bllow down the tail pipe this will force the smog out the starboard side and the port side will bring in air make sure the car is on when your doing this.
    there are other options for the men who dont llike to blow.......?? you can stick a fruit (apple) down the pipe and cut of the excess apple, then drive 4 miles west 4 miles east and 2 miles home take out the apple and ur prob. is solved. dont worry about ur car stalling because of the port side valve will bring in air as will the intake and the starbored will blow the bad smog out...... if u here bad sounds like sputtering dont worry the starbored is not often used and is getting warmed up.
    glad i could help..... ur friendly pipe blower
  5. tedwright
    tedwright Senior Member
    UPSTATE NY
  6. CRX-YEM
    Wallingford, CT
    Simple answer NO
  7. rudeludenotmeanthough
    rudeludenotmeanthough Senior Member
    yea, wtf??
  8. enixu4
    enixu4 Junior Member
    What part of emissions are you failing? Cause two leading probs are the HO2 sensor or it could be the catalytic converter. I just recently did my emissions on my 94 civic ex and failed the first time b/c my HO2 sensor had just blew on me that same day then bought one and replaced it within 30mins and passed this time. Oh btw HO2 sensor failing (should) show a check engine light, if not check to see if you're failing your CO readings for emissions that's what it will fail on. Hope that helps.
  9. CRX-YEM
    Wallingford, CT
    It's an O2 sensor, or somtimes called a lambda sensor
  10. enixu4
    its the same thing, H is for heated.
  11. E_SolSi
    ummmm no
    just because you mean something one way doesnt make it correct
    written the way you did, the "H" would mean hydrogen
    HO2 is termed either hydroperoxyl radical or perhydroxyl radical (the protonated form of superoxide)
    that would make it either a hydroperoxyl radical or perhydroxyl radical sensor
    cars dont measure that
  12. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    are we talking about boats or cars??? wtf.... :hmm: :hmm:
    Milan
  13. dvus1
    dvus1 Senior Member
    somewhere in GUAM
    Ill take the car to the inspection line again so ill find out whats it failling
    ( what sensor )..... :D
  14. CRX-YEM
    Wallingford, CT
    you shouldn't need to take it again, they should of given you a paper printout
    of what the levels for CO(Carbon Dioxide), NOx(Nitrides of Oxygen), HC(Hydrocarbons)
    they should be in units of ppm's (parts per million)
