emissions
Discussion in 'General Tech and Maintenance' started by bluenutz5, Mar 1, 2005.
  1. bluenutz5
    bluenutz5 Senior Member
    chicago
    ok guys im not passing emissions... i have a chipped p28 on my h22 integra and the charts say im flowing too much fuel! i have a new cat on so its not that... and i have a fuel pressuer regulator....i used my vafcII to lean it out to -2 all the way threw 6500rpms on low cam....do i need to lower it more or what do u guys think could be the answer? go back to the stock p13? lower the fuel to -5? let me know what you guys oppinion is?
  2. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Is your timing set correctly? Are you throwing any codes? A chipped ECU can sometimes hide codes.
  3. bluenutz5
    chicago
    no im not throwing codes and i belive my timing is right i have skunk2 cam gears and they are boyh set at zero...is that wat it should be at? my maintanince required light is on but i dont know why? not my check engine lite... and i just changed the oil a week ago... so im stumped
  4. tab
    tab Super Moderator
    Aberdeen, Washington State
    Who chipped the ECU? If it's one of those EBAY H22 chips, then it's probably dumping fuel into the motor. Their idea of tuning is making the whole powerband rich.
  5. bluenutz5
    chicago
    i bought it from a performance shop for $300 it was chiped by skunk2 dont know if it was directly from there or wat....but what do u guys think about leaning it out to -5 on my vafc?
  6. erikespo
    erikespo Senior Member
    Western New York
    can you monitor your a/f ratio? if you can lean it out till it is not rich anymore.. make sure your plugs are burning as much fuel as they can too..
    check those plugs too..
  7. bluenutz5
    chicago
    what do u mean by plugs? spark plugs? and no i dont have a a/f guage.....
  8. dohcvtec_accord
    The left lane
    It most definitely is not chipped by Skunk2. It's a knockoff. As tab said, it's just dumping a buttload of fuel into your cylinders.
    That said, you could try leaning it out with a VAFC, but it's going to be tough to figure out where you should lean it to without using a wideband O2 sensor.
  9. bluenutz5
    chicago
    so wat if i put the p13 back in?
  10. dohcvtec_accord
    The left lane
    I'm willing to bet that would fix your problem, and make your car run and perform better as well.
  11. bluenutz5
    chicago
    but the p13 has a rev limit of 6500! that will make my car run better?
  12. dohcvtec_accord
    The left lane
    P13 has a rev limit of 7800 rpm.
  13. bluenutz5
    chicago
    tthe one i had the fuel cut off was at 6700 rpms.......i dont understand why?
  14. dohcvtec_accord
    The left lane
    A P13 will stop VTEC from engaging (hence a 6500 rpm revlimit) if it detects any codes. Was it throwing a code?
  15. bluenutz5
    chicago
    no not at all and if i get the p13 put back on what should i set my vtec to..right now i have it at 5200rpm to low or can i go lower and what should i have it disengage at?
  16. wanderinman
    wanderinman Senior Member
    Raleigh, NC
    Your engine maintenance light is just a reminder light for you... it flashes after 4500 miles and stays on constant at 6000. To reset it reach under your dashboard, slightly right of the steering column, and you'll feel a small black buttong (or just look up under there). As soon as you turn the car on, hold that button down for about 5 or 6 seconds, and you'll see the light go off. After that you got another 4500 until you have to do it again!
  17. erebunicrx
    erebunicrx my name is Dale
    Bristol ct
    put the p13 back in go to the emmisions station go back home and put the chipped ecu back in. no matter what you need to go to the dyno or get a wideband o2 to get the a/f right.
  18. tab
    tab Super Moderator
    I agree.
    For now use the P13. You can engage VTEC at 5k and have the fuel cutoff no higher than 8k ish. Mine cuts off at 7600. The P13 is better than a knockoff program.
  19. bluenutz5
    chicago
    ok so use the p13 set the vtec at 5000rpm and what do i wana set it to disengage at? right now its at 5000rpm and engages at 5200rpm...keep in mind i dont wana kill a shit load of gas but yet still have the power!!!
  20. bluenutz5
    chicago
    wait now that i think about it...when i had the p13 in i didnt have the vtec wires hooked up so is that why the cut off was at 6500? bc of no vtec?
