engine advice
Discussion in 'Engine Building' started by stockcarracer, Nov 4, 2011.
  1. stockcarracer
    stockcarracer New Member
    hi folks i'm new to this honda malarkey lol,i was wonderin if anybody could steer me in the right direction.is it possible to fit a 1.5 sohc vtec head onto a 1.6 non vtec bottom end? :confused:and is it possible to fit a sohc head on a dohc block?:confused: as i have these sitting and wondered if it was possible to mate them together,i would be runnin a set of twin carbs on it.all advie greatly appreciated
  2. E_SolSi
    :yes:
    typically :no:
  3. 99sidude
    Ohio
    The sohc head will fit with the use of JB Weld.
  4. stockcarracer
    99sidude
    hi and thanks 4 the advice,nots ure what you mean by it'll fit with the use of jb weld?
  5. Ethan
    Ethan Well-Known Member
    dont use jb weld! keep it jdm and just hondabond it on!
  6. dc4dude
    dc4dude Member
    chicago, il
    :rofl::rofl::rofl::rofl:...bwaaaahahahahahahahahaha!!!!!!!!
  7. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    He is being facetious. Most DOHC head will not bolt on to a SOHC block.
  8. 98EkSi
    98EkSi New Member
    And lots of duck tape, got to have the duck tape.
  9. 98EkSi
    98EkSi New Member
    Only a DOHC ZC head and it would not be simple as parts like timing belt would be hard to figure out. Plus it would not be a worth while motor ro build as is would not make much power compared to a SOHC Vtec head. But B series is always better :rimshot:
  10. phunky.buddha
    Dallas / Fort Worth, TX
    Search "mini-me" around the site. Lots of information about putting a VTEC head onto a non-VTEC D series block. There should be an article or two in the reference section too.
