Ok i have a 96 sol si and when i go to start it the engine acts like it isnt getting enough fuel but its fine after that. I was thinkin it was just the fuel filter so i was gonna check it but i don't know where it is located. So any help would be appriciated. thanks guys
i believe you have three size 10mm bolts holding the filter to the firewall.
you need a size 12mm socket to remove the top and to disconnect the bottom you need a 12mm open-end wrench to take it off.
