engine buildup
Discussion in 'Engine Building' started by slow89teg, Aug 15, 2004.
  1. slow89teg
    slow89teg Junior Member
    I wanted to know can a d16a1 engine get built up to support a turbo setup?
  2. jamesA
    Sure, what is your budget and what are your goals?
  3. slow89teg
    My budget is about $1000 as of right now. Do you think the upgrade is possible with that amount? I just want to be able to push it once in a blue. If i could get 200 hp to the ground that would be nice.
  4. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    think the sohc bolt on kits hit almost 200whp with standard entry level boost settings.
  5. slow89teg
    How much is the kit and will it bolt up to my teg? Also where could i find it at the lowest price?
