Originally posted by hcivic.com@Nov 30 2004, 02:28 PM
what have you doen to it?
have you changes you plug cap and rotor. timed it properly
[post=424259]Quoted post[/post]
Originally posted by hcivic.com@Nov 30 2004, 02:38 PM
ok it was an si?
have you used a timming light on it?
[post=424262]Quoted post[/post]
Originally posted by valentino@Nov 30 2004, 05:21 PM
I been working on my car for a while now and i can't seem to fix the problem. Ok heres the problem. The car runs ok, but when i slam the gas pedal to the floor the engine chokes. When i slowly press on the gas pedal it run ok. Please someone help me.
[post=424256]Quoted post[/post]
Originally posted by zoomspeed05@Dec 1 2004, 11:09 AM
hey i just got finishing fixing this problem check the throttlebody it mite be clogged
[post=424565]Quoted post[/post]
Originally posted by GSRCRXsi@Dec 3 2004, 12:01 PM
if you have obd1 injectors you dont need the injector box. if you have obd0 injectors, you need the injector box.
[post=425892]Quoted post[/post]
Originally posted by valentino+Dec 3 2004, 01:31 AM-->zoomspeed05@Dec 1 2004, 11:09 AM
Someone was telling me about not to use the resistor box coz, d16z6 doesn't require it. is it true?
[post=425689]Quoted post[/post]
Originally posted by valentino+Dec 3 2004, 02:47 PM-->Originally posted by valentino@Dec 3 2004, 01:31 AM
Checked throttle body and it look fine. Anything else? Any suggestions?
[post=425966]Quoted post[/post]
Originally posted by valentino+Dec 4 2004, 03:16 AM-->Originally posted by valentino@Dec 3 2004, 02:47 PM
Anyone?
[post=426230]Quoted post[/post]
Originally posted by pissedoffsol@Dec 5 2004, 10:45 AM
if you're using the p28 ob1 ecu and obd1 injectors, you must NOT run the resistor box.
[post=426556]Quoted post[/post]
Originally posted by GSRCRXsi@Dec 5 2004, 10:32 PM
get a distributor plug from an obd1 civic or integra.
note: this is NOT the clip for the ignition distributor. i say distributor for lack of a better word. this is a plug which has 1 input and 4 outputs. it splits the power to all four injectors from one wire. that would be the way to do it and thats what you do with your remaining wires.
[post=426880]Quoted post[/post]
Originally posted by preluderjs@Dec 6 2004, 01:14 AM
i had a similar problem in my car and it would only do it right around full boost (1.8t) and it turned out to be the MAF sensor. I dont know if that would help you at all but good luck.
[post=426912]Quoted post[/post]
