Engine Code flashing every 4 seconds
Discussion in 'HYBRID -> BA-BB /CA-CD' started by HONDAPITSTOP, Oct 2, 2003.
  1. HONDAPITSTOP
    HONDAPITSTOP Senior Member
    Hi,
    I have a 1994 JDM H22A engine and I jumped the service connector and the engine light flashes for about 1 second in duration every 4 seconds. Would anyone know what this pattern of flash translates and refers to code and problem wise? Sorry I don't have my helms manual yet so I can't look it up just yet. Unless the codes are listed on this site somewhere?
    TIA for any help :worthy:
    Bruce
  2. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Articles section y0!
  3. dohcvtec_accord
    The left lane
    And by the way, that's Code 10, Intake Air Temp sensor. :)
  4. HONDAPITSTOP
    Thanks Chris :D LOL, I thought it might be somewhere but I keep getting interupted with real work today LOL. I should have just ask you in the first place but at least if someone else has the same error code they'll see this thread ;)
    Plus, once I get the code cleared I'll post the fix here baybay!
    Thanks again, Bruce
  5. dohcvtec_accord
    The left lane
    Well, like I said in that memo I wrote you, I'm 95% positive that it's bad wiring, probably right at the spot where we lengthened the IAT wiring. I've replaced the IAT sensor and that's not the problem. It's either a faulty ECU (unlikely) or bad wiring.
  6. HONDAPITSTOP
    True it could be the wiring or something like that.
    Refresh my memory about how the codes work again.
    If it is a code 10 then I should see a 1 second long light with 4 seconds of pausing for a total of 10 lights and then how long should it pause before it restarts the sequence? What would a Code 1 look like? What I'm getting at is I could have missed the reset pause but it looks like it never takes a longer pause than 4 seconds so would that mean it's a code 1 instead of a code 10 ? Just trying to make sure I'm reading the sequence correctly.
    Bruce
  7. tab
    tab Super Moderator
    Aberdeen, Washington State
    ten is one long flash. One is one short flash. Eleven would be one long, one short, then a pause. There is a pause between every code for a few seconds.
  8. HONDAPITSTOP
    Ahhh ok I get it now. I've only had to deal with error codes two times so thanks for the tips.
    Bruce
