Engine Codes,, Help now
Discussion in 'General Tech and Maintenance' started by walid_105, Jul 11, 2005.
  1. walid_105
    walid_105 Junior Member
    Ok so i know its the B16A, now i got the clock signs wirtten down from over the headers.
    1/6 <-- or 1/9 <-- or 7/6 <-- or 7/9 ( its upside down so i dunno what is what, its one of the four) then it's , \5 , 3|2 , 6|0 <- or b|0
    some help would be apreciated on that. I also got the tranny number.
    J1-1007992
    Engine code is , B16A 1214120 HM.
    Also, what can I do with the engine mounts from enjo, did they not fit because the tranny is hydrolic? or the fittings are all the same?
    Thanks..
  2. ripperbone
    ripperbone angry bear
    Oklahoma
    the tranny mounts are different between the clutch tranny and the hydro tranny.
  3. walid_105
    so how do i tell if its hydro or cable?
  4. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    Cable trans has a lever on the front side of the trans. Hence physical cable pulling the clutch.
    EDIT: can't speed, corrected. :lol:
  5. walid_105
    My trany is J1.... so it must be a cable tranny. Now for the engine what parts can I buy for it ..
    del sol
    integra ect??
