Engine cooling with home made turbo kit
Discussion in 'Forced Induction' started by some white guy, Apr 6, 2004.
  1. some white guy
    some white guy Junior Member
    ive looked around for a bit, but cannot find out how you would still run cooling fan(s) for your engine with a turbo setup? Do you just use 2 of the fans that mount in front of the radiator, like the ones on the a/c condensor?
  2. ilikepie
    ilikepie Senior Member
    Emmm run a half radiator with one fan?
  3. pissedoffsol
    depends on the car and your manifold.
    some manifolds you can still run ac
    some will let you run a full size integra radiator
    others, no a/c, and a civic-sized half radiator is required
  4. some white guy
    its a 90 civic ex, with a d15b2 running a STD manifold... all the similar pics that i saw showed a full size radiator, but about 1' of clearance... but no fans... i remember seeing a fan that went on the front of the radiator before, i might have to use 2 of those, and maybe an aluminum radiator if i can get a heat shield for the turbo and manifold...
  5. pissedoffsol
    a 92+ civic half sized radiator is more than enough cooling. pick up one from any civic, and and hack on a foot in the middle for a support bar
  6. reckedracing
    reckedracing TTIWWOP VIP
    NY
    and you can always get a slim fan, just make sure its way clear of the turbo or you're gonna melt it and waste whatever money you shelled out for it
  7. jeffsciv23
    jeffsciv23 Senior Member
    Wa
    i had to remove the AC and then move the radiator over about 1.5-2".
