Engine crankshaft
Discussion in 'General Tech and Maintenance' started by Ivan323, Mar 2, 2007.
  1. Ivan323
    Ivan323 New Member
    Hi guys, its me again. :)
    I wanted to check with u guys tat if example my engine crankshaft n engine bearings had been damage b4 but will the problems arise even after i had change the re-con crankshaft n new bearings as well?
    Do u guys recommend me to change another engine instead repairing by replacing it?
    Thank u for the all of u guys...
  2. boostin4fun
    boostin4fun Boosted ls/vtec ohh yeah!
    Omaha
    I would start with another crankshaft that hasnt had any spun bearings. Then I would have it micropolished and balanced, about $100 by a repebutable machine shop. Make sure you go with oem honda bearings and that they are properly clearanced.
  3. Ivan323
    Ivan323 New Member
    So its not necessaries to change the whole engine and wad i need to do is to find a good condition crankshaft n oem bearings.
    The problem won't arise anymore unless wear n tear which i believe is a long time..
    Am i rite?
  4. boostin4fun
    Omaha
    You wouldnt have to replace the whole engine, however you would be taking it basically all of the way apart!! So if you are not knowledgeable about rebuilding engines and putting them back together right I wouldnt attempt it. If thats the case it would be much easier and a better idea for you to get another engine thats in good shape.
  5. Ivan323
    Ivan323 New Member
    I will bring it to workshop if i rly need to replace the crankshaft becos i'm not familiar with re-buliding my engine ..
    By the way, will my performance increase if i would to use B20 crankshaft on my B18C?
  6. boostin4fun
    Omaha
    You cant use that crank it that block without custom rods or pistons it has a longer stroke. Stick with the b18c crankshaft.
  7. Ivan323
    Ivan323 New Member
    Oh ok...
    Thanks ya..
    I was very worried becos i just brought tis engine not long ago n someone was telling me tat if happens tat a engine crankshaft n bearings won't last long even i haf change to a new set becos its had damage before..
  8. Ivan323
    Ivan323 New Member
    Nope.
    Sorry for the poor gammer..
  9. Ivan323
    Ivan323 New Member
    Oh ok ...
    Thanks anyway.. :)
  10. Ivan323
    Ivan323 New Member
    Anyway, i got myself a used B20 crank n con rod at a good prices but need a bit of mod to fit into the engine..
    May i ask u something, any different for the lower block between B16B(ek9) n B18C(DC2)?
    Any way tat i can verify it?
  11. Ivan323
    Ivan323 New Member
    Yey, me know as well the difference is stroke only..
    Any others can help me ?
  12. Ivan323
    Ivan323 New Member
    Great..
    Thanks for the info.. :)
