Engine cutting out
1995EGGuy
My b16a sir-ii is cutting out when i stop sometimes. it has a new tune up and the fuel pressure is ok someone told me boefre it could be the igniter in the dizzy. Do these go bad alot? and cause it the cut out at a dead stop?
The igniters on mine went once, the thing just stopped and never started again, I had to get new ones (well junkyard) ones to get her back up and running. Check your vaccuum lines, that could have something to do with it, or maybe your air idle adjustment needs tweaking?
