"Engine Dampeners"
Discussion in 'General Tech and Maintenance' started by Andrew, Apr 21, 2006.
  1. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    Just lookin 'round Ebay and came accross these 'engine dampeners' from NR-G.
    Basically a 'shock' from the block to the firewall.
    Think they'd do any good? or is it just a shiny shock in your engine bay?
  2. E_SolSi
    get real mounts
  3. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    +1 to what E said, if you need one of these, build it yourself from autozone mini shock absorbers (like for the hatch glass/truck camper glass)
    $20 instead of 45... we made one of those open the hood.
    Usually it goes on the side and the hood sticks up and looks like shit, but if you mount it to the side of the brake booster it closes right too :p
  4. vanillakilla
    vanillakilla Senior Member
    Tacoma Washington
    it looks pointless to me [​IMG]
  5. phunky.buddha
    Dallas / Fort Worth, TX
    w3rd
    Just get solid mounts.
  6. TurboMirage
    the alternative to solid mounts.
    hockey pucks are .99 cents. ive been rolling on two completely solid mounts for about 5K miles now.
  7. Andrew
    Tallahassee, FL
    I don't think it's meant to hold the engine up, used as an engine mount.
    I think it's supposed to hold the engine from moving?
    Please don't think I'm going to buy that crap... I'm just curious. i've never heard of them before..
    -Andrew
  8. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    I've seen the engine braced on the upper strut tie bar before, on a spoon racecar or someone similar, but never seen dampeners used before for that purpose.
  9. 97CTR
    97CTR Senior Member
    these have been around for a few years. A few different company's make them. Because there is only one "damper" they have been known to cause an engine to actually twist becasue of the difference in support.
  10. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    There are torque mounts in the front and rear of the engine that prevent it from rocking back and forth(to a certain extent; bushing stiffness).
  11. Andrew
    Tallahassee, FL
    And thats what I'm saying they are, but didnt really make it clear i guess..
    I was just wondering if they were effective?!
  12. MikeBergy
    Central Coast, CALI
    Maybe, but why would you put a 45$ damper on your car when you can go spend 30 for a set of poly mount inserts that are proven?
  13. Eye Heart Boost
    Eye Heart Boost Member
    Colorado
    lol.. that's actually called a torque dampner and it absorbs the forward/backward engine movement. IMO, it's an absolute must, but don't buy a cheap eBay one, it WILL break. Check out the Ingalls Engineering dampner.. they are quality stuff.
    www.ingallseng.com
    Pricey, but well worth it. It will help greatly reduce (if not eliminate) wheel hop.
  14. MikeBergy
    Central Coast, CALI
    as I questioned before, what does it do, that motor mount inserts do not? Energy suspension makes the same exact claim to eliminate wheel hop with it's poly inserts. Not trying to be a jerk. I've just never seen them used in any honda engine bays I've seen, motor mounts/inserts are an easy/inexpensive path to the same mountain top, unless I'm missing something.
  15. Eye Heart Boost
    Colorado
    Several of my friends use them and the dampen the movement on the upper half of the motor. Consider this.. the lower half has what, 5 mounts? What's the top half (head and up) have to keep it from moving? Nothing... thus this part.
  16. TurboMirage
    most people that are new to modding cars dont want to fuck with motor mounts.
    its 10x easier to install a damper.
    on my mirage, there are two torque mounts underneath, one on the tranny, and one on the upper part of the block.
    the two torque mounts are hockey pucks. the motor DOES NOT MOVE. ever.
  17. MikeBergy
    Central Coast, CALI
    The two torque mounts with poly inserts should be more than enough for the average joe, but I guess I can see trying anything if you still have engine movement with the poly inserts. I imagine higher hp engines might move a little easier, even with poly inserts. And there are only 2 or 3 torque mounts on hondas that actually keep the engine from moving. the side mounts only hold the engine up. no more no less.
    Regardless, it seems like a worthless waste of money to 99% of people out there.
  18. Andrew
    Tallahassee, FL
    Huh.. so hockey pucks fit directly in there eh?(just with a hole drilled through the middle?)
    I'd imagine it'd be too big in diameter..
  19. TurboMirage
    no its not a direct fit.
    mine required trimming the diameter for both mounts.
  20. Andrew
    Tallahassee, FL
    Nothing power tools can't make quick work of....
