engine harness question
Discussion in 'HYBRID -> ED-EF / DA' started by chdb2005, May 19, 2008.
  1. chdb2005
    chdb2005 Junior Member
    will any b16 obd1 harness work with any b16obd1 harness from a different model car? my guess is yes because b16 to b16, VTEC to VTEC, DOHC to DOHC. another question is do all different obd1 ecu's all have the same connectors from harness to ecu
  2. D16SiHatch
    D16SiHatch New Member
    try as i may, i dont know what the it is you're asking or trying to figure out
  3. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    Depends on the car. For example, a 2000 civic si engine harness will not work in a 95 civic with a b16a engine. The harness' have to match locations, like shock tower connection and so forth.
