Hey fellas, I have a question. I have a 94 GSR.. I bought it from an insurance auction completely stripped.. Obviously I needed to choose a motor.. I decided to go with a B16a sir2 simply because it was all I could afford at that time (should have went with a b18c)..
I basically have finished the whole swap, however, the engine's harnesses don't match up with the car's harnesses.. I figure that I could just purchase & replace the b16 harness with a GSR engine harness and everything should plug and play.. The problem is, I can't find a GSR engine harness anywhere! I have however, found a 94 si harness (d16z6 OBD I).. So here comes my question...
First, is the si and gsr engine harness basically the same thing???? Meaning if I throw the si engine harness on, will it plug and play with my car's harnesses??
Secondly, am I approaching this wiring problem the right way?? I am not completely sure if I know what I talking about.. I just heard from a friend that this is possible..
If you have any suggestions or comments... It would be very appreciated!!
Thanks a lot
Thanks a lot
