Your motor should come with the JDM harness, just undo the loom and tape, and remove hthe vtec plug and wires all the way to the canon plugs, and pop the pins out. Then since your lucky, and have a 92 you can find where the wires that come imbedded in the ECU to engine bay harness are in your cars canon plug, and pop the vtec wires pins in there, then run it into your loom and plug it into the motor.
