i just swaped my gsr into a 99 civic ex witch was a d16 car and im having trouble hooking up the engine wiring harness is there a web site or somthing that tells me what goes where ?
well you could buy a OBD1 to OBD2 converter if ya motor is an OBD1 motor, or you can cut and rearrange lots of wires lol... try rewire.com
OBD1 or OBD2 will wire into this car PLUG AND PLAY as long as you have the engine harness AND the ECU harness. chances are your motor is obd1 in this case you will have a 2 part harness. ek b16 are the only harnesses that are single piece hanesses.
i need help i got a 96 ek hatch but ma car runs choppy when i floor it it dnt pick up it just wants to turn off i need help i got a difrent harness but they dnt plug up i needa y7 harness
