Engine Help? swap
Discussion in 'Civic and del Sol - EG and EK' started by 95EJvtec, Jan 21, 2010.
  1. 95EJvtec
    95EJvtec New Member
    I wanna do a swap but which engine would be best for me? i want a engine that will produce good numbers. But it has to be a Daily Driver for me. i want the engine to be All-motor none of that Turbo BS.. Straight motor Horsepower baby!! lol
  2. 95EJvtec
    95EJvtec New Member
    Oh and i got A 1995 Civic EX Coupe (EJ) , the current engine is A D16z6 350000+ miles on it
  3. EG93sir
    EG93sir Racer X 904
    jacksonville fl
    LS would be a good daily driver,find one with low mileage if you can,clean straight forward and affordable on a budget,lots of fun too.
  4. BrutalB83
    Rochester Hills, MI
    B18C1 (GS-R) would be my choice for a reliable but fun, daily-driven Civic...
  5. EG93sir
    EG93sir Racer X 904
    jacksonville fl
    gsr's aren't that easy to come by down here in the south,ls's are plentiful
  6. 95EJvtec
    95EJvtec New Member
    I was Thinking About an B18c5 , what do you guys think?
  7. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Those are OBD2 only and needs adjustments or replacement of dizzy to OBD1, OBD1 Alternator, OBD1 injectors (prelude DOHC VTEC are same size) and use your D16Z6 engine harness
    PLus these swaps are at least $1200 more then a B18C1
  8. EG93sir
    EG93sir Racer X 904
    jacksonville fl
    If you take your time,do lots and lots of research(ths forum will help a GREAT deal)and your budget can handle it,Go for it!!Good luck.
  9. pooksy64
    pooksy64 RidetilldeathdousparT
    HOUSTON tX
  10. 95EJvtec
    95EJvtec New Member
    my budget is prolly about 2500
  11. phunky.buddha
    Dallas / Fort Worth, TX
  12. phunky.buddha
  13. 95EJvtec
    95EJvtec New Member
    what does a B18c5 usually cost?
  14. phunky.buddha
    Close to $4000, then the parts to refresh the engine, then the mounts to put it into the car (or use OEM ones, might still have to spend some cash), then any other cash you need to spend to troubleshoot anything that might have gone wrong during the install.
  15. phunky.buddha
    Or you could just go to Hmotorsonline.com as a few of us have already linked and look through their pricing. They have just about every engine you could think to drop into a Civic.
  16. ejay8
    ejay8 New Member
    ik this thread is a bit old but i have a question, im tryn to swap my 98 ex civic with a gsr motor from hmotorsonline and i was planning on buying the complete swap.. since the engine would be jdm would i have to replace certain parts for this swap to come through?
  17. phunky.buddha
    Come through what? To function properly- no.
  18. ejay8
    ejay8 New Member
    Ok.. So is the t bracket and driver side mount and a couple cables the only parts that need to be changed?
