Engine Help
Discussion in 'Engine Building' started by ethan02908, Apr 7, 2003.
  1. ethan02908
    ethan02908 Junior Member
    I bought this b16a block ,the top surface deck was damaged from shipping.My question is ,Is it ok to resurface the deck and use thicker head gasket?. I want to resurface about .010 inch.thanks
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    you can probably resurface .010 and still use a normal head gasket. you'll even enjoy a little compression bump!
  3. D See 2
    D See 2 Senior Member
    Baltimore, MD
    w3rd
  4. ethan02908
    will the pistons trevel pass the deck surface? .thanks
