Engine Id
slipvayne
Member
I was wondering how do i tell what engine. I know its on the block somewhere but i cant find it. its a 86-90 honda engine. sohc 12 valve., Thanx
look on the block up front near where it connects to the tranny
youll see a flat square
the code will be there
it might be all covered and caked with shit so you cant read it
if it is then hit it with some brake cleaner and wipe the shit off
thats not it.... it should be "D15**"
it will look like this B16A2
Alright, that little plate with the number on it, is not there.The spot you showed me was right next the the exhaust manifold. I have looked up and down that spot. I even removed everything that was in the way. Is there any other place it could be. Thanx for the help you guys :worthy:
