T TT01Fanatic I Nov 18, 2008 #1 Hey, in need some help guys, just wondering what the stock engine is in my 89 Civic Sedan LX. Thanks Email me if you want, tt01fanatic@gmail.com Thanks
johnboymartin666 New Member Nov 18, 2008 #3 [edit] D15B2 Found in: 1988-1991 Honda Civic GL/DX/LX 1988-1991 Honda CRX DX 1992-1995 Honda Civic LSi Hatch/Saloon (European Market) 1990-1995 Honda Concerto (European Market) Displacement : 1,493 cc (91.1 cu in) Bore and Stroke : 75 mm × 84.5 mm (3.0 in × 3.3 in) Rod Length : 134 mm Compression : 9.2:1 Power : 92 hp (69 kW) @ 6000 rpm & 119 Nm @ 4500 rpm Valvetrain : SOHC (4 valves per cylinder) Cam Gear : 38 tooth Piston Code : PM3 Fuel Control : PGM-FI Dual Point (OBD0) Redline : 6500 rpm (6000 rpm honda concerto)
S sevenhillsbilly New Member Nov 18, 2008 #4 you can look on the engine tag on the block too to find out just for future reference
