i've checked all hoses and have added more than enough coolent for the rest of the cars life. i've heard that it might be the thermameter or the water pump. if so does anyone know how to check on either of the above named.
skunk2 IM, headers, front mount intake, spark plugs and wires, clutch, flywheel...that's it, how would i check for the timing (distibutor?) what does timing have to do with engine cooling.
ok i've got it, found out what the problem was, there seems to be a leak underneath the car, it comes out of a plastic tube that is cut in on either sides. I think it's the heater motor that is leaking the fluid out, does anyone know of anything else.
The heater core hoses go from the engine side of the thermostat housing to the firewall, at least in my teg they do. You must be leaking a TON of water out to overheat it that quick. Like the other guys said, check all your coolant hoses, and make sure all you connections and clamps are tight.
yea if you dont bleed it you'll have air in the cooling system, which overheats motors easially. My friend had his crx after he swaped his engine, didnt know you had to bleed it, and just poured antifreeze in(no water at all). he drove like 1 1/2 miles and didnt watch temp gauge and blew er up. I dont know what the kid was doing swapping his engine, if he dosent know the basics of automechanics.
bleeding the coolent is pretty easy right, all you need to do is add coolent to its level and its mixture and leave the radiator cap off while the engine is runnin' right? wait just a for maybe 30 secs to a min. and put the cap back on right? and then check coolent level and add as necessary right? plus have heater on full blast... anyone know of any other methods?
No. On the thermostat housing is a bleed screw. open it up, and fill the radiator till you get a steady amount of coolant coming from the screw. that gets all the air out. Then fill up the overflow to the level on the bottle.
