when driving at low rpm up to 4k(in every gear) i hear like a rattle noise(sounds sort of like somthings loose) from the engine. i have looked under the car and have not seen anything obvious that was loose. can this noise be the engine knocking?
heres my set up i just got
>b18c1 odb1 in EG(95si)
>polished crank
>CTR over size
>over size bored
>honed
>clean
>dected
>JDM rods
>ITR valuetrain set
>New crank bearings-rod bearings all new .
>Dc 4-1 header
>oil pump- water pump
>8.5 wires
>ENGINE balanced double check clearance -rods-and main bearings
im am currently running a p28 w/hondata. now if it is the engine knocking, can i just use an ecu that looks for a knock sensor?
any suggestions will help thanks!
>polished crank
>CTR over size
>over size bored
>honed
>clean
>dected
>JDM rods
>ITR valuetrain set
>Dc 4-1 header
>8.5 wires
