Engine Knocking?
Discussion in 'Engine Building' started by mattcalica, Feb 26, 2003.
  1. mattcalica
    mattcalica Senior Member
    okay, my b16 is knocking, i think. at idle, every so often, theres like a putter and the rpm drops like 100...is this considered knocking? heres the thing, my distributor is almost all the way advanced, and when i try to bring it back to tdc, it starts puttering even more. i have a field vafc, so is there a way to change the fuel ratio so that the puttering stops? should i make it richer of leaner?
  2. chevy302dz
    chevy302dz Senior Member
    Your engine is not knocking. Bring the timing back in were it should then check everything. It sounds like a idle or fuel problem and by advancing the timing your just masking the problem.
  3. cws13
    cws13 Senior Member
    Athens,GA
    Your cam timing is most likely off. Check your ignition timing with a light. If your timing has greater advance/retard than you can adjust with the distributor, your off a tooth.
