All b series engines have the exact same mounting holes and the transmissions are the same, excluding cable transmissions. All you need for this swap is a 99-00 si rear mount. If you want it to be really stiff (recomended) get the torque mounts too. Also get the mount inserts while you are at it, they are cheap and will really help you.
