engine mount question
Discussion in 'HYBRID -> ED-EF / DA' started by intafocus, Mar 18, 2009.
  1. intafocus
    intafocus New Member
    irvine, ca
    will a 99 sohc vtec motor bolt up to my ef without modification
  2. murray195
    murray195 Member
    Calgary, AB
    No. You need to use the search feature my friend! You're getting into electrical, ECUs, mounts, cable vs hydro, etc.
  3. Da1andonlyJinx
    Da1andonlyJinx New Member
    Florida
    He is just asking if it will bolt up. Yes, if it is a d-series then it will bolt up to your stock manual tranny and your motor mounts. Now if you want it to run then that is were your problem starts.
    If you want to put this in your car the best thing to do is wire it up for multi point if it isn't already then convert to obd2a or obd2b not sure which one. for that to happen you would need the dizzy, ecu, injectors, jumper harness.....I think thats it. More trouble than it is worth if you ask me.
  4. 8ballsin
    8ballsin New Member
    Heidelberg,Germany
    to make it bolt right in you have to take the complete driver side mount off your old motor and put it on the new one
