Engine overheating please help
Discussion in 'General Tech and Maintenance' started by CTR1806, Oct 3, 2007.
  1. CTR1806
    CTR1806 New Member
    Hey,
    I just swap a jdm integra type R engine in my 99 honda civic ex i kept the stock civic radiator, and it just keeps on overheating. I already changed out the thermostat and its still doing the same thing. there is no pressure in any of the lines. And i cant hear or see anything leaking out of the car. Pleas help me out im out of ideas.
  2. Fibercation.com
    Fibercation.com Banned
    Ohio
    blown hg
    trade me for my gsr swap it runs :)
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    first post in the right area, second make sure your fan is coming on, and check and see if its the rad is filled all the way up
  4. ls ef
    ls ef New Member
    lol
  5. Rasputin
    Rasputin New Member
    Hell
    if there is no pressure in the water lines it has to be either the thermostat (which you have changed, did you put it in correctly) or water pump. I guess some engine importers shove socks, towels, rags and paper in the open places, you did pull those out right ?
  6. noobvang
    noobvang Senior Member
    Twincities, MN
    You did fill up the block AND the radiator right?? Bleed the coolant system?? Leaking anywhere??
