FObangah
Member
for the how do you bleed it question..... get a 10m box wrench and break the valve lose BEFORE you start the car incase it wants to be a bitch so the car doesn't get hot while your fighting it. Make sure you have plenty of towels and atleast another half jug of coolant. Once you break it lose, snugg it tight then start the car. loosen the bleeder just enough for coolant to bleed out. I theres any air in the system, you will see coolant kind of sputter out... let it sputter until it completely stops and the flow is even and consistent. Once the air is out of the system, kill the car and top it off with coolant. I normally repeat the process again just to make sure its fully clear. It would be better to have a clear tube to attach to the bleeder valve ( so you can see the bubbles) but the coolant you spilt on the ground would be a tasty treat for that neighbor hood cat that likes to spray piss/leave foot prints on your ride. 2 birds with one stone!
