Engine Problems
Discussion in 'Civic and del Sol - EG and EK' started by Aj56, Oct 15, 2011.
  1. Aj56
    Aj56 New Member
    Sup!! I have a problem with my H swap in my Ek.My question is "what is causing my car to vibrate on the driver side".Okay I replaced the axle but there's a bracket at the bottom back of the tranny that mounts to the chassis..Its missing two bolts could that be the cause of the vibration anyone. Any info would be helpful..
  2. E_SolSi
    that could be the cause
    also look for a bad engine mount
