Engine stand
Discussion in 'HYBRID -> EG-EK / DC' started by SOHCD16y8, Dec 25, 2004.
Thread Status:
Not open for further replies.
  1. SOHCD16y8
    SOHCD16y8 Junior Member
    Northwest Indiana
    I have just purchased a B18b1 and am goin to start rebuilding the block on an engine stand, however i am not sure what bolts to use to mount the engine to the stand and what holes to use. I know most of the time you just use the trans bolts but the stand i have wont allow it to happen like that. It has a four inch hole for the bolts to go thru first before it goes into the block and pictured here Engine stand (top left 1000 pound capacity)
    What size bolts should I use on the block and what holes to use?
    thanks
  2. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    go to a parts store and buy some longer metric bolts
  3. brian11to1
    brian11to1 Senior Member
  4. driver1
    driver1 Senior Member
    take a bell housing bolt out and bring it to a parts store and get some bolts that are the same diameter and thread pitch btu just longer so they can go through the stand and into the block
  5. erebunicrx
    erebunicrx my name is Dale
    Bristol ct
    remember fine thread :)
  6. SOHCD16y8
    Northwest Indiana
    I dont have any of the original bolts because i bought the engine and trans separate but i looked it up at work (autozone). I went and got 2 m12 x 1.25 4 inches long for under the head and 2 7/16 inch ones that were 4 inches long for the bottom left and bottom right holes and used anti seize on the threads and washers to protect it, worked great, got all grade 8 bolts by the way, thanks for the replies
  7. brian11to1
    Ok, sense it was that easy was this thread that helpful?
  8. SOHCD16y8
    Northwest Indiana
    i was a little i guess, i was looking for more direct answer than what i got buts its done now so it doesnt matter
  9. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    This is not Swap-related. This is the Swap-related forum.
    Try again in the right forum.
    :locked2:
Thread Status:
