Engine Swap 92 prelude SiR
Discussion in 'HYBRID -> BA-BB /CA-CD' started by Ludester, Jun 19, 2005.
  1. Ludester
    Ludester Junior Member
    I was just wondering what engine would be best to put in my 92 prelude sir? I took out the stock HF-2-2A. Now i'm not sure what to put in. Any advice, would be greatly appreciated.
  2. reikoshea
    Dallas, TX
    whyd you take it out. The H22A is the best engine for that car as far as im concerned.
  3. tab
    tab Super Moderator
    Aberdeen, Washington State
    Well, H or F? F22 is bottom of the line, H22 is top of the line. Also, knowing which one you had will help determine your best course.
    H22 is DOHC VTEC. F22 is SOHC non-vtec.
  4. reikoshea
    Dallas, TX
    well if its the sir its the H22
  5. tab
    tab Super Moderator
    I didn't think the Prelude had an SIR. I think that was an Accord. The Prelude has SI, Type S, Atts models.
  6. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    He could be located somewhere other than the US. Honda offered a Prelude SiR elsewhere. I'm just too lazy to search. :D
  7. lude9593
    lude9593 Senior Member
    Mt. Pleasant, NC
    i think the sir was offered in canada and probably europe. not sure though. i'm too lazy to search as well.
  8. reikoshea
    Dallas, TX
    There was an SiR model, but it wasnt produced in america, and it had an H22A
  9. Ludester
    The SiR was produced in Japan. It is stamped HF-2-2A. Im not to sure if it is the F2-2A or what. I've been searching everywhere to find out, no luck :(
  10. dohcvtec_accord
    The left lane
    Does it say DOHC VTEC on the valve cover?
  11. reikoshea
    Dallas, TX
    yeah thats the easiest way to tell, but from the research i did the SiR only had the h22 in it.
  12. Ludester
    No it doesn't say anything on the valve cover. The guy i bougth it from said it has a 2.3 if that helps... If it is the h-2-2 all i will have to do is change the crank shaft, but if it is the F-2-2 what would i be able to swap it for? and would i need any modifications to make it fit? I appreciate your help guys. I wana get this car on the road asap!!!
  13. reikoshea
    Dallas, TX
    Well if it has a 2.3 then it is a H23...question answered.
