engine swap b18a1 into 94 civic ex
Discussion in 'HYBRID -> ED-EF / DA' started by civicboy07, Jun 21, 2007.
Thread Status:
Not open for further replies.
  1. civicboy07
    civicboy07 New Member
    i have the block, head,and ecu. and i was wanting to know what all i would need to do this swap. by what every one says it is an easy swap and i would also like to know if i can use my wiring harness from the d16 if i bought a obd1 to obd0 pigtail and the cv axles
  2. invisibledemon
    Tn
    yeah, youll use your harness from your car. you may have some unused plugs though since your going from obd1 to obd0.
    youlll need the complete engine (intake, exaust, all that good stuff)
    shift linkage.
    motor mounts.
    transmission of course.
  3. Bigblue98
    Bigblue98 New Member
    What about running a b18a1 block with the gsr head or b16 head? i also want to run vtec so how would i set that up?
  4. Bigblue98
  5. invisibledemon
    Tn
    this thread is 4 years old.
    try starting one of your own or searching first.
Thread Status:
