Engine swap check engine light
Discussion in 'HYBRID -> EG-EK / DC' started by kustomcarbuilder, Dec 11, 2008.
  1. kustomcarbuilder
    kustomcarbuilder New Member
    Hello. I have a 1994 Civic. I swaped out my d series engine for a b18c. Its a JDM GSR. I keep throwing a engine light for a knock sensor. I changed the sensor, and it didnt fix the problem. I had to wire the vtec and other needed wires for my swap. I purchased a swap harness kit that had all the needed wires in a sub harness that just plugged into the ECU. All the wires look good and are stongly connected to the ECU. Light will not go out. Any info or tips would be great.
  2. t3t4delsol
    t3t4delsol New Member
    York, Pa
    what ecu are you running?
  3. victor carrillo
    victor carrillo New Member
    can u tell me how to wire the vtech
  4. 95b16coupe
    95b16coupe New Member
    ct
    nope, but you can do a search. it's posted a million times on this forum.
    oh, and start your own thread.
  5. kustomcarbuilder
    The serial number is 37820-p72-013 972-104641. It was the one that came with the engine when i bought it.
  6. kustomcarbuilder
    Its a P72 with OBDII and engine code is B18C.
  7. monotech
    monotech Member
    Make sure you have the knock sensor wire connected on the correct pin location D3=KS for Obd-1 only.
  8. kustomcarbuilder
    Where should the wire be? My civic is OBDI and my engine is OBDII but i got the OBD converter harness.
  9. kustomcarbuilder
    Anybody got any other tips?
  10. bluemk3
    bluemk3 Supra & Civic-T Owner
    Altoona/ Pittsburgh
    dont quote me on it but i believe if youare running and obd1 you can disable the knock sensor without any engine effects this will take away the engine light. some people have to do this when using p28. liek i said dont quote me but look into it i think it may be your issue
  11. kustomcarbuilder
    Light Still on
    Knock sensor in correct spot. What else could throw the code? My buddy metioned to just disable the knock sensor. Is that worth the time and engine?
  12. bluemk3
    Altoona/ Pittsburgh
    i think its manditory with no ill effects on a jdm motor
  13. monotech
    monotech Member
    Just disable it won't affect your performance :thumbsup:
  14. kustomcarbuilder
    How do I disable the knock sensor
    How do I disable the knock sensor on a JDM engine any links with pics and instructions would be great?
  15. monotech
    monotech Member
    Knock sensor is disabled on the eprom inside the ecu meaning it would have to be chipped.
