ENGINE SWAP d16y7 to b18c1
Discussion in 'Civic and del Sol - EG and EK' started by Jones570, Mar 9, 2010.
  1. Jones570
    Jones570 New Member
    i have a 98 civic cx (EK hatch) with a D16Y7, what exactly do i need to put a b18c1 in it. (motor mounts, ecu, axles, ect....)
  2. Jones570
    Jones570 New Member
    anyone?
  3. SLP10
    SLP10 New Member
    You need a crate motor swap.
    Motor(Long Block)
    Valve Cover to Oil Pan including distributor, Intake manifold, Exhaust Manifold
    Hasport B Series into EK Motor Mounts
    Trans
    ACT Clutch
    Linkage
    Axles
    Engine Harness
    ECU
    Your car is non-VTEC which means for a VTEC motor swap you need to run the one or 2 wires with your engine harness into the car's ECU.
    might as well get a bigger radiator while your at it too.
    Start There see what happens
  4. adamiano86
    adamiano86 New Member
    I'm doing the same swap - have you bought the engine yet? Let me know what you find out - I still need to buy the engine, but I would like to get all of the parts at once - what websites were you lookin at to buy from?
  5. JUNiOR24
    JUNiOR24 New Member
    i got a 96 dx coupe and
    i did this same swap to my car a couple months back
    do u knw what u need?????
  6. ejay8
    ejay8 New Member
    doing a similar swap in about a month, got a 98 civic ex going for b18c1, would this swap fit right in? buying a complete motor swap from hmotorsonline.. ive been told everything would fit, yet i see people saying axels need to be changed, any ideas???
  7. JUNiOR24
    JUNiOR24 New Member
    to this swap u will need a couple of things
    if its a gsr motor u have to get:
    gsr axles
    gsr ecu
    gsr shift linkage
    back t bracket from a 99-00 civic si
    driverside post mount from a 99-00 civic si
    the gsr wire harness will NOT fit a civic
    you could use your sohc vtec harness on it
    you would just have to extend some wires
  8. ejay8
    ejay8 New Member
    Thanks man.. Is it just two wires to extend or add?
  9. serrilion
    serrilion In my own little world! VIP
    Vermont
    ya. You will need to run the wires for the oil pressure switch 1 to the ecu and the other 1 to the neg on the batt or a ground elts were, and the other 1 comes from the vtec sylonoied on the motor. All this can be found on hondaswap in the search section. Just type in vtec wire up lol
  10. ejay8
    ejay8 New Member
    Lol I'm new here aha.. Thanks for da info
  11. carylight
    carylight New Member
    ijust swapped a d16z6 for my 1.5 non vtec ina 1995 civic same year engine now the transmission performs badly , the fluid level is fine but it acts like its low on fluid, does not shift til 3500-4000 rpm. My question is do i need a transmission to match this engine please help, thanks
  12. jdm 96 ek
    jdm 96 ek New Member
    can u sell ur d16y7 motor harness
  13. hatchbuild10
    hatchbuild10 New Member
    Cali
    I got a b18c1 out of a gs-r and i am looking to get rid of it for a good trade or cash. I have the wire harness and the ecu, shift linkage and axles. It currently sits in a 96 civic ex.
  14. azcivic00
    azcivic00 New Member
    i got one question, what modification will i need to do to my "y8" wire harness to my B18c1 swap?
    your insight would be awesome...
    i'mma newbie
  15. hatchbuild10
    Cali
    when I did the swap I had a buddy help me all we did was modify the o2 sensor and we put in the obd2 fuel injectors.
