Engine Swap ECU Question
Discussion in 'Civic and del Sol - EG and EK' started by casinophil, Jan 3, 2010.
  1. casinophil
    casinophil New Member
    I'm swapping a OBD2A engine into my OBD2B car and i'm using the ecu jumper. My question is i can't find my M/T ECU for the new engine but i have a A/T ecu laying around for the same year engine. My question is will the A/T ECU work even though im using a M/T engine and harness which doesn't plug into the A/T connector on the ECU.
  2. HRTuning
    HRTuning New Member
    Phoenix, Arizona
    It will run if you get the three main connectors plugged in. You'll throw Automatic Transmission error codes.
  3. casinophil
    So CEL will be on until i get the right one? But will it idle correctly?
  4. HRTuning
    HRTuning New Member
    Phoenix, Arizona
    Yes, getting the proper ECU is always the answer.
    Possibly. The ECU will make changes when a CEL is present, so I can't say for sure. Normally on OBD1, it would.
