to both.
I say, turbo the D17 and invest the other $8-9k.
by the time its all done you will see,you got a long way to goWhy not build a K series Frank Swap for WAY LESS than 8-9k... trust me. Im building one at the moment and im only 3g into it.
In other words, that price is a false representation of the real price.
and if you want the same power as a k20 just buy a turbo kit on ebay for 800$ with all the hardware instalion kit. gonna give you between 205 and 217 whp depend of your boost setup. for a lot cheaper then the k20 swap.
so are you saying you got that kind of power with out a turbo or spray ??ok first of all, the d17 can support over 250whp with out a piston, rod and crank shaft job. i got an Civic ex 2001 with a setup that devlop 265 whp and 217 lbs with out turbo kit. first if you want a good setup on those engine change the head if you got a d17a2, the a1 head is non-vtec and is better for hi-compression setup. Up next you will need to regrind your cam shaft, change your valves, springs and retainer, port and polish head, cam gear, fuel rails, injector, customizable ECU, race header and exaust, uperdrive pulley and overdrive pulley + flywheel.
its gonna cost you less than a k20a swap, its gonna give you better boost anyway, and over all the d17 is lighter then the k serie so for slalom, track, drag or just street use , with a good suspension setup, your car will be over a lot of car, trust me. tested and approved.
