engine swap issues?
mike kelley
I have installed a d16z6 engine in a 91 civic hb...I am not using the vtec..... I reused the 1.5 intake and injection system here, My issue is that there are 2 sets of wire blocks on the d16 dizzy . I got an adapter that works with the existing engine harness but I still need to figure out how to hook up the other wire plug coming from the dizzy..... Can anyone help me with this?
if you are using the original stock OBD0 PM5 or PM9 ECU, you need to use the stock OBD0 distributor that was originally on your stock engine, however, you will find that it will not bolt onto the D16Z6 head - leaves you in a tough spot
yeah, I know about the dizzy issue.... just trying to make the obd1 dizzy work... If I can find the correct wire adapter I think it will work.
