I need to know what all i will need to swap a 98 d16 into a 87 integra such as wireing harnesses etc. I need to no everything
umm all i have to ask is why why why why wtf and why you will have to change all your motor mount locations......... it is is non-vtec you can use your ECU if is vtec...you can still use your ecu and the vtec activated via a switch....the DOHC ecu will have enough gas for the vtec' and again why?
