Engine swap
Discussion in 'Prelude' started by ride_hard12, Jan 17, 2007.
  1. ride_hard12
    ride_hard12 Chris
    im going to change my engine soon, ive just ordered a used b20a5 with 45,000 miles on it and im going to swap it in my 91 lude si that has the b21a1. now can anyone give me a detailed order that i need to follow to take out my engine and drop in my new one. thanks a bunch.
  2. 1Funryd
    1Funryd Member
    Is this a USDM or JDM engine? The differences will be the engine harness, as the B21A1 is OBD1 and the B20a5 is OBD0.
    All you will need to do is swap all your external parts from your old engine on the the B20a5 engine. Once you pull your engine if you have two engine stands, you should be able to compare the differences, which will be very minor.
    Both engines will have all the same bolt holes and patterns. So, keep all your original external engine parts ie...intake manifold, egr, powersteering, altenator(unless you want the newer one) etc..
    You will need to keep the engine harness from your old setup as, the B20a5 has some differences.
    That is about all I can say, if you need more help come over to www.preludepower.com we have the biggest 3rd gen community by far with the most helpful information.
    Sean
  3. ride_hard12
    ride_hard12 Chris
    ok well thank you so much, but what else do i have to worry about as far as the OBD1 wire harness that i already have in the car, do i have to change it for the B20A5 or what?
  4. 1Funryd
    1Funryd Member
    I gave you all I know. You must do the rest of the research yourself on the site above.
    Sean
  5. eludethis
    eludethis Junior Member
    no you don't have to change your harness unless you wnat to use the B20A5 intake mani or you want to convert to OBD0. which is not what i would recommend.
    1Funryd is correct. but allow me to be more specific. what sean means is you will need to switch these parts from your B21A1 onto your B20A5.
    intake mani
    exhaust mani
    thermostat housing
    use your old tranny
    that's about it! now go get your hands dirty.
    hey Sean (1Funryd)
    what's up. i'm loving my H22 mounts man! you truly are a credit to the 3rd gen community.
  6. 1Funryd
    1Funryd Member
    Your welcome!! I am proud to be part of this momentous turn in 3rd Gen History!!
    Sean
