engine swap
atlballazz06
i was wondering if anyone had any good information on a 95 civic gsr swap on showing me step by step on how to do it im still searching tho cause i know this came up tons of time thanks in advace this is my first swap and i just want everyting to be perfect i have the honda engine swaps book by aaron bonk but i want to be 125% sure on everything everybodys advice if u have done it before and what i should look out for would help
If you bought the complete GSR changeover it is relatively easy swap.
You can use a combination of your stock engine mounts & the GSR engine mounts to make the engine and trans bolt into your car. Beyond that all you need to do is run the wires for the VTEC components and the IAB, which you can find on this site, and you'll be good to go.
If you have any other questions reply with what you need.
